Traxxas nous sort une version miniaturisée des funny cars, vous savez les dragsters
Lien vers la page de présentationCette bête peut monter à plus de 70 MPH, soit environ 110 KM/H
Caractéristiques:
The Traxxas Funny Car reaches speeds in excess of 70mph!*
Powered by the Traxxas ET-3s Electronic Speed Control with custom programming exclusively for authentic drag racing
Traxxas ET-2400 brushless motor (2400 Kv)
Scale Funny Car "tube-style" tub chassis
Modular simplicity, fiber-composite chassis
Quick-release front body hold down and replica tilt-up body
Functional, adjustable wheelie bar
Inboard front suspension system
Adjustable 3-link rear suspension with sway bar
Quick-release battery hold down
Direct-drive transmission
Oil-filled sealed differential
Oversized 6mm rear axles
Threaded-body, oil-filled GTR shocks permit fast, precise preload adjustments and deliver smooth, consistent damping
Single point steering with integrated servo saver
Specially engineered belted slick rear tires (2" wide rear)
Contoured, molded rear tire inserts
Front Funny Car Race Replica tires
Mirror-chrome 5-spoke Race Replica wheels
Digital high-torque waterproof micro steering servo
Enclosed receiver box
TQi 2.4GHz High-Output radio system with Traxxas Link model memory:
- Exclusive, patent-pending Burnout, Staging, and Race Modes
- Patent-pending Launch Control system with adjustable torque setting
- Automatically stores and loads settings for up to 30 Traxxas Link-enabled models—
- just switch on and drive, "model selection" is not required.
- Multi-Function knob with torque control
- Adjustable steering and throttle percentage (dual rates)
- Adjustable steering and throttle sensitivity (exponential)
- Adjustable steering and throttle end points
- High 13ms frame rate and near-zero latency for responsive control
- Telemetry-enabled 5-channel micro receiver with dual channel-1 inputs
- Compatible with optional TQi Docking Base (#6510) for full Traxxas Link App capability with Apple iPhone or iPod touch (sold separately)
Et le prix annoncé est...assez conséquent:
499$ soit environ
430€ Et il faut acheter ca aussi:
LienPrix:
?Et ca:
LienPrix:
70$Plus la/les lipo(s)
En gros, il faut prévoir 499+?+70=569$ sans le kit de comptage et la/les lipo(s)
Je sais pas vous, mais j'essayerai bien
...si ca ne coutait pas aussi cher
Bye
