Hobbyking nous à sortit un recepteur compatible Spektrum DSM2 3 voies à pas cher, soit 19,99$ environs 16€!
Le voici:
http://www.hobbyking.com/hobbyking/store/__23784__OrangeRx_GR300_Spektrum_DSM2_3Ch_2_4Ghz_Ground_Receiver.htmlLes caractéristiques:Compatible with all Spektrum DSM2 ground transmitters.
OrangeRx receivers are built using original components and MCUs and with state of the art SMT automation to ensure a quality product each and every time.
All OrangeRx receivers are QC tested before leaving the factory.
The OrangeRx GR300 will work with ANY Spektrum DSM2 2.4Ghz ground transmitter
At only 5.7g in weight and 28.7x20.6x11.9mm in size the OrangeRX GR300 is Great for tight fits inside waterproof casings or modern touring car chassis with limited space.
Key features.Super light weight and compact
Compatible with DSM2 ground systems (car & boat applications)
Built in fail safe
Specs:Channels:
3Size: 28.7x20.6x11.9mm
Antenna length: 135mm
Input voltage:
3.5~8.4VFaile safe:
YesWarranty.12 Month replacement guarantee!
Included.OrangeRx GR300 DSM2 Compatible ground receiver
Bind plug
Bind and fail safe instructions
NOTE: 1) This is not a Spektrum receiver, nor is it a copy of a Spektrum Receiver.
The Spektrum brand is a trademark of Horizon Hobbies USA.
2) Price of this receiver may fluctuate (up or down) due to cost of electronic components.
3) This is not an underground manufactured fake Spektrum receiver. OrangeRx quality is guaranteed.
4) This receiver is for the current generation of DSM2 transmitters. It is not compatible with legacy DSM transmitters.
Voilou!
