je reprends le sujet de Mag' pour en faire un uniquement pour les contrôleurs compatible avec le Savage XS Flux
Les contrôleurs:HPI/Castle:Le Flux VAPOR Pro
Cet ESC est compatible avec le castle Link, il est probablement d'origine Castle!
With the capacity to handle 2S and 3S LiPo power, the Flux VAPOR Pro electronic speed control can take anything you can possibly throw at it and keep coming back for more! The VAPOR Pro features an integrated cooling fan to keep it cool in tough conditions. The Flux VAPOR Pro ESC is reversible so you can back out of jams with ease. And for maximum adjustability it's fully programmable with our optional #100573 USB Programming Kit.
Les connectiques utilisées sur ce controleur sont des bullets 4mm.Lien Constructeur:
http://www.hpieurope.com/piw.php?lang=en&partNo=106767FLUX Q-BASE BRUSHLESS ESC
The Flux Q-Base Brushless ESC is one-half of the Flux Brushless system that is fitted as standard in the Savage Flux 2350, forming an unstoppable power force for amazing off-road power!
With the ability to handle twin 2S LiPo batteries (that's 14.8 volts of LiPo power!) it can deal with anything the Alphastar 2350 motor can dish out! 4mm bullet connectors secure the motor wires for loss-free connection to the 13-gauge wires, and to connect to each battery pack we've attached real Deans
connectors for zero power loss and total efficiency. We figured why re-invent the wheel and release our own connector when the best is already available?
Les connectiques utilisées sur ce controleur sont des bullets 4mm.Le lien constructeur:
http://www.hpiracing.com/products/en/104924/Les photos de Dj' pour voir comment il se positionne sur le chassis du XS Flux:
HPI BLUR
Equipe les Savages 1/8, donc c'est très(trop puissant?) pour le XS, mais si on a ça de côté, ça rentre, et ça ne chauffera pas!
Specs:
•25.2V maximum with Flux Tork 2200Kv brushless motor
•16.8V maximum with Flux Tork 2650Kv brushless motor
•Sensorless technology eliminates additional sensor wiring and complexity
•Cells: 6s LiPo
•Continuous: 120A*
•Resistance: 0.0003 ohms per phase
•Brake: Proportional with adjustable curve
•Reversible: Yes - with lockout
•Low Voltage Cutoff: Programmable
•Size: 2.2" x 1.9" x 1.4"
•Weight w/wires: 121g (4.26 oz)
•Connector: 6.5mm bullet
Les connectiques utilisées sur ce controleur sont des bullets 6.5mm.Le lien constructeur:
http://www.hpiracing.com/products/en/100684/Les photos de Dj' que je remercie encore! Il faudra couper les 4 poteaux de rétention du Flux Vapor Pro pour adapter cet ESC:
Castle:Le Mamba Max Pro, fait parti des ESC compatible, même si la fixation sera peut être a retoucher.
Les caractéristiques:
Compatible 6S
L: 1.79” (45.5mm)
W: 1.44”(36.5mm)
H: 0.85” (21.5mm)
81g (2.8 oz)
Connection: 4mm bullet
http://www.castlecreations.com/products/mamba_max_pro.htmlLe Qbase est en fait un Mamba Max Pro rebadgé par HPI, donc les photos (juste au dessus) pour le positionnement du Qbase sont aussi valable pour le Mamba Max Pro.
Le Mamba Monster
Spec:
Compatible 6S
120A en continue.
Voltage du Bec: 5.5v fixed output
Connecteurs: 6.5mm bullet
http://www.castlecreations.com/products/mamba_monster.htmlLe HPI BLUR est en fait un Mamba Monster rebadgé par HPI, donc les photos (juste au dessus) pour le positionnement du HPI BLUR sont aussi valable pour le Mamba Monster.
TEKIN:Surtout pour les Moteurs TEKIN avec capteur, ces RS et RS PRO de chez Tekin peuvent être très utile, et restent un choix Fiable et pas trop cher:
EZRUN/XERUN/HOBBYWING:Le Xerun 150A est clairement surdimensionné par rapport a la bête, mais 2 avantages:
Son prix(en moyenne 78€ livré)
Il rentre dans le XS!
1 Specification
1.1 Output: Continuous 150A, burst 950A.
1.2 Input: 6-18 cells NiMH/NiCd or 2-6S LiPo. (But 2S lipo or 6 cells NiMH is not recommended)
1.3 BEC: 5.75V/3A (Switch mode built-in BEC).
1.4 Resistance: 0.0002 Ohm.
1.5 Motor Supported: Sensorless and sensored brushless motors.
1.6 Suitable Motor: * Note #1
When working with 4 cells Lipo: KV<=3000
When working with 6 cells Lipo: KV<=2400
1.7 Suitable Car: 1/8 On-road/Buggy/Truggy/Monster competition.
1.8 Size: 58mm(L) * 46.5mm(W) * 35mm(H).
1.9 Weight: 105g (Without wires).
*Note #1: The above KV number is the value of a 4274 sized motor (Diameter=42mm, Length=74mm).
http://www.hobbywing.com/product_show.asp?id=238Un lien sur brushlessmania ou se trouve une traduction en Français de la notice de ce controleur:
http://brushlessmania.forumpro.fr/t4428-notice-du-xerun-150a-80a-en-francaisMerci Mag'
Si vous avez essayé d'autre contrôleur pour le XS Flux, posté içi
