| [S][Demande de partage] Feuille de réglage Xerun 150A | |
| Sujet: [S][Demande de partage] Feuille de réglage Xerun 150A Dim 3 Fév 2013 - 17:18 | |
| Salut à tous J'aurai voulu savoir comment vous réglez vos Xerun Punch et Timing etc... Voici la fiche par défaut livré avec le Xerun : Options -> | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | Basic Items | 1. Running Mode | Forward with Brake | Forward/Reverse with Brake | Forward and Reverse | | | | | | | 2.Drag Brake Force | 0% | 5% | 10% | 20% | 40% | 60% | 80% | 100% | | 3.Low Voltage Cut-Off Threshold | Non-Protection | 2.6V/Cell | 2.8V/Cell | 3.0V/Cell | 3.2V/Cell | 3.4V/Cell | | | | 4.Start Mode(Punch) | Level1 | Level2 | Level3 | Level4 | Level5 | Level6 | Level7 | Level8 | Level9 | Advanced Items | 5.Max Brake Force | 25% | 50% | 75% | 100% | Disable | | | | | 6.Max Reverse Force | 25% | 50% | 75% | 100% | | | | | | 7.Initial Brake Force | Drag Brake | 0% | 20% | 40% | | | | | | 8.Neutral Range | 6% (Narrow) | 9% (Normal) | 12% (Wide) | | | | | | | 9.Timing | 0.00 ° | 3.75 ° | 7.50 ° | 11.25 ° | 15.00 ° | 18.75 ° | 22.50° | 26.25° | | 10.Over-heat Protection | Enable | Disable | | | | | | | | 11.Motor Rotation | Counter Clockwise | Clockwise | | | | | | | | 12.Lipo Cells | Auto Calculate | 2 Cells | 3 Cells | 4 Cells | 5 Cells | 6 Cells | | | |
Voici mes réglages : Options -> | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | Basic Items | 1. Running Mode | Forward with Brake | Forward/Reverse with Brake | Forward and Reverse | | | | | | | 2.Drag Brake Force | 0% | 5% | 10% | 20% | 40% | 60% | 80% | 100% | | 3.Low Voltage Cut-Off Threshold | Non-Protection | 2.6V/Cell | 2.8V/Cell | 3.0V/Cell | 3.2V/Cell | 3.4V/Cell | | | | 4.Start Mode(Punch) | Level1 | Level2 | Level3 | Level4 | Level5 | Level6 | Level7 | Level8 | Level9 | Advanced Items | 5.Max Brake Force | 25% | 50% | 75% | 100% | Disable | | | | | 6.Max Reverse Force | 25% | 50% | 75% | 100% | | | | | | 7.Initial Brake Force | =Drag Brake | 0% | 20% | 40% | | | | | | 8.Neutral Range | 6% (Narrow) | 9% (Normal) | 12% (Wide) | | | | | | | 9.Timing | 0.00 ° | 3.75 ° | 7.50 ° | 11.25 ° | 15.00 ° | 18.75 ° | 22.50° | 26.25° | | 10.Over-heat Protection | Enable | Disable | | | | | | | | 11.Motor Rotation | Counter Clockwise | Clockwise | | | | | | | | 12.Lipo Cells | Auto Calculate | 2 Cells | 3 Cells | 4 Cells | 5 Cells | 6 Cells | | | |
Et voici le tableau à coller dans votre réponse : - Code:
[table border=1] [tr][td]Options ->[/td][td]1[/td][td]2[/td][td]3[/td][td]4[/td][td]5[/td][td]6[/td][td]7[/td][td]8[/td][td]9[/td][/tr] [tr][td]Basic Items[/td][/tr] [tr][td]1. Running Mode[/td][td]Forward with Brake[/td][td]Forward/Reverse with Brake[/td][td]Forward and Reverse[/td][td][/td][td][/td][td][/td][td][/td][td][/td][td][/td][/tr] [tr][td]2.Drag Brake Force[/td][td]0%[/td][td]5%[/td][td]10%[/td][td]20%[/td][td]40%[/td][td]60%[/td][td]80%[/td][td]100%[/td][td][/td][/tr] [tr][td]3.Low Voltage Cut-Off Threshold[/td][td]Non-Protection [/td][td]2.6V/Cell [/td][td]2.8V/Cell[/td][td]3.0V/Cell[/td][td]3.2V/Cell[/td][td]3.4V/Cell[/td][td][/td][td][/td][td][/td][/tr] [tr][td]4.Start Mode(Punch)[/td][td]Level1[/td][td]Level2[/td][td]Level3[/td][td]Level4[/td][td]Level5[/td][td]Level6[/td][td]Level7[/td][td]Level8[/td][td]Level9[/td][/tr] [tr][td]Advanced Items[/td][/tr] [tr][td]5.Max Brake Force[/td][td]25%[/td][td]50%[/td][td]75%[/td][td]100%[/td][td]Disable[/td][td][/td][td][/td][td][/td][td][/td][/tr] [tr][td]6.Max Reverse Force[/td][td]25%[/td][td]50%[/td][td]75%[/td][td]100%[/td][td][/td][td][/td][td][/td][td][/td][td][/td][/tr] [tr][td]7.Initial Brake Force[/td][td]Drag Brake[/td][td]0%[/td][td]20%[/td][td]40%[/td][td][/td][td][/td][td][/td][td][/td][td][/td][/tr] [tr][td]8.Neutral Range [/td][td]6% (Narrow) [/td][td]9% (Normal) [/td][td]12% (Wide)[/td][td][/td][td][/td][td][/td][td][/td][td][/td][td][/td][/tr] [tr][td]9.Timing [/td][td]0.00 ° [/td][td]3.75 ° [/td][td]7.50 ° [/td][td]11.25 ° [/td][td]15.00 ° [/td][td]18.75 ° [/td][td]22.50° [/td][td]26.25°[/td][td][/td][/tr] [tr][td]10.Over-heat Protection [/td][td]Enable [/td][td]Disable[/td][td][/td][td][/td][td][/td][td][/td][td][/td][td][/td][td][/td][/tr] [tr][td]11.Motor Rotation[/td][td]Counter Clockwise[/td][td]Clockwise[/td][td][/td][td][/td][td][/td][td][/td][td][/td][td][/td][td][/td][/tr] [tr][td]12.Lipo Cells [/td][td]Auto Calculate [/td][td]2 Cells[/td][td]3 Cells[/td][td]4 Cells[/td][td]5 Cells [/td][td]6 Cells[/td][td][/td][td][/td][td][/td][/tr] [/table] Il suffit de sélectionner votre réglage puis de le passer en gras
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Dim 3 Fév 2013 - 22:14 | |
| Re Aurel! Merci pour ça! J'éditerais ce message dans la semaine avec ma config' |
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Lun 4 Fév 2013 - 5:29 | |
| Salut tout le monde Pour cex qui n'y comprenne rien au code, vous pouvez m'envoyer les reglages par MP, je vous ferais le tableau |
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Dim 10 Fév 2013 - 8:53 | |
| Yop Alors Ça n'intéresse personne Allez les gars Postez moi juste les chiffres et je ferai la mise en page si vous voulez Matt, tu n'as pas les réglages par défaut car sinon tu n'aurais pas de marche arrière |
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Dim 10 Fév 2013 - 11:33 | |
| Salut Aurel! hop! Options -> | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | Basic Items | 1. Running Mode | Forward with Brake | Forward/Reverse with Brake | Forward and Reverse | | | | | | | 2.Drag Brake Force | 0% | 5% | 10% | 20% | 40% | 60% | 80% | 100% | | 3.Low Voltage Cut-Off Threshold | Non-Protection | 2.6V/Cell | 2.8V/Cell | 3.0V/Cell | 3.2V/Cell | 3.4V/Cell | | | | 4.Start Mode(Punch) | Level1 | Level2 | Level3 | Level4 | Level5 | Level6 | Level7 | Level8 | Level9 | Advanced Items | 5.Max Brake Force | 25% | 50% | 75% | 100% | Disable | | | | | 6.Max Reverse Force | 25% | 50% | 75% | 100% | | | | | | 7.Initial Brake Force | Drag Brake | 0% | 20% | 40% | | | | | | 8.Neutral Range | 6% (Narrow) | 9% (Normal) | 12% (Wide) | | | | | | | 9.Timing | 0.00 ° | 3.75 ° | 7.50 ° | 11.25 ° | 15.00 ° | 18.75 ° | 22.50° | 26.25° | | 10.Over-heat Protection | Enable | Disable | | | | | | | | 11.Motor Rotation | Counter Clockwise | Clockwise | | | | | | | | 12.Lipo Cells | Auto Calculate | 2 Cells | 3 Cells | 4 Cells | 5 Cells | 6 Cells | | | |
Mais j'ai rien modifié par rapport à l'origine, j'ai juste calibré puis c'est tous... Je vais le mettre exactement comme toi tu l'as mis, et on verra si le problème persiste. T'es sur quel version dans firmware upgrade? HW437_V5.0_150A V1.00_111207a_2r Au suivant!! |
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Dim 10 Fév 2013 - 12:14 | |
| salut , alors les miens ça doit être çà zut de zut j'y arrive pas a mettre en gras mes réglages sont casi les mêmes que toi Aurell sauf le timing qui est a 3,75 , max brake force a 75% et max reverse force a 75% le timing je n'ose plus y touché car une foie j'ai eu un bug , le moteur saccadait et ne décollait pas mais du coup en voyant ton réglages je sais plus encore au suivant |
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Dim 10 Fév 2013 - 12:40 | |
| Salut les gars - killbuteur a écrit:
- zut de zut j'y arrive pas a mettre en gras
Pas de soucis Paramétrage de killbuteur : Options -> | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | Basic Items | 1. Running Mode | Forward with Brake | Forward/Reverse with Brake | Forward and Reverse | | | | | | | 2.Drag Brake Force | 0% | 5% | 10% | 20% | 40% | 60% | 80% | 100% | | 3.Low Voltage Cut-Off Threshold | Non-Protection | 2.6V/Cell | 2.8V/Cell | 3.0V/Cell | 3.2V/Cell | 3.4V/Cell | | | | 4.Start Mode(Punch) | Level1 | Level2 | Level3 | Level4 | Level5 | Level6 | Level7 | Level8 | Level9 | Advanced Items | 5.Max Brake Force | 25% | 50% | 75% | 100% | Disable | | | | | 6.Max Reverse Force | 25% | 50% | 75% | 100% | | | | | | 7.Initial Brake Force | =Drag Brake | 0% | 20% | 40% | | | | | | 8.Neutral Range | 6% (Narrow) | 9% (Normal) | 12% (Wide) | | | | | | | 9.Timing | 0.00 ° | 3.75 ° | 7.50 ° | 11.25 ° | 15.00 ° | 18.75 ° | 22.50° | 26.25° | | 10.Over-heat Protection | Enable | Disable | | | | | | | | 11.Motor Rotation | Counter Clockwise | Clockwise | | | | | | | | 12.Lipo Cells | Auto Calculate | 2 Cells | 3 Cells | 4 Cells | 5 Cells | 6 Cells | | | |
- le timing je n'ose plus y touché car une foie j'ai eu un bug , le moteur saccadait et ne décollait pas mais du coup en voyant ton réglages je sais plus encore
Effectivement, c'est un réglage à bouger avec précaution En principe pas de risque majeur mais si ca déconne, je pense qu'il faut remonter d'un cran voir 2 pour être tranquille Avec un frein comme ça, tu ne dois pas mettre longtemps à t'arrêter Pour ma version, il me semble bien que c'est celle là d'ailleurs, il y a une mise à jour du soft Hobbywing USB link en V3.2
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Ven 15 Fév 2013 - 10:14 | |
| salut , je viens de branché au pc en fait mon timing est sur 15 aussi comme je viens d'installé un 2000kv léopard a la place du 1450 kv je vais revoir tout ça de prêt et je verrais la différence de réglages entre les deux ( le 2000kv sur le flux et le 1450kv sur le 666) @+ |
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Ven 15 Fév 2013 - 11:38 | |
| Salut Killbuteur Fiche modifiée Tiens nous au jus pour tes tests |
GazatokLe rodage Messages postés : 37 Age : 49
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Lun 11 Mar 2013 - 11:24 | |
| Salut a tous, j'ai conservé tous les reglages d'origines mais pas encore fait l'update Par contre, j'ai monter les cut-off a 3.4v/cell ( Je suis en en 2x3s Zippy 5800). Qu'en pensez-vous? Descendre à 3.2v n'est pas limite pour la durée de vie des lipo? merci , Nico |
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Lun 11 Mar 2013 - 12:03 | |
| Salut gazatok regardes à combien tes lipo descendent à la fin d'un run mais généralement, le Xerun coupe avant c'est pour ça qu'on peut le baisser un peu mon cut off est à 3.0v. Pense aussi à fixer ton nombre de lipo Vérifies quand même bien tes réglages au cas ou il ait quelques chose de bizarre |
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Lun 11 Mar 2013 - 12:50 | |
| Merci Aurel pour ta réponse. Tu penses alors qu'il ne vaut mieux pas laisser l'Esc en mode auto pour la detection Nico |
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Lun 11 Mar 2013 - 13:08 | |
| salut , pour la détection il vaut mieux réglé sur le nombres de cellules directement par contre pour le cut off je suis sur 3,0 v mais là j'ai une lipo sur les deux qui délire quand je les recharge séparément l'une des deux met 68 mn alors que l'autre 233 même plus je suis plus sur du coup je vais le remettre sur 3,2v des foies que (je placerais des tof dans le post de mon flux) @+ |
TitineboyPremières casses Messages postés : 112 Age : 47
| Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A Lun 11 Mar 2013 - 18:53 | |
| Salut, Voici mes réglages de mon Xerun pour l'instant : Options -> | Run 1 | Run 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | Basic Items | 1. Running Mode | Forward/Reverse with Brake | Forward/Reverse with Brake | Forward and Reverse | | | | | | | 2.Drag Brake Force | 0% | 5% | 10% | 20% | 40% | 60% | 80% | 100% | | 3.Low Voltage Cut-Off Threshold | 3.2V/Cell | 3.2V/Cell | 2.8V/Cell | 3.0V/Cell | 3.2V/Cell | 3.4V/Cell | | | | 4.Start Mode(Punch) | Level4 | Level5 | Level3 | Level4 | Level5 | Level6 | Level7 | Level8 | Level9 | Advanced Items | 5.Max Brake Force | 50% | 50% | 75% | 100% | Disable | | | | | 6.Max Reverse Force | 25% | 25% | 75% | 100% | | | | | | 7.Initial Brake Force | Drag Brake | Drag Brake | 20% | 40% | | | | | | 8.Neutral Range | 9% (Normal) | 9% (Normal) | 12% (Wide) | | | | | | | 9.Timing | 11.25 ° | 15.00 ° | 7.50 ° | 11.25 ° | 15.00 ° | 18.75 ° | 22.50° | 26.25° | | 10.Over-heat Protection | Enable | Disable | | | | | | | | 11.Motor Rotation | Counter Clockwise | Counter Clockwise | | | | | | | | 12.Lipo Cells | 4 cells | 4 Cells | 3 Cells | 4 Cells | 5 Cells | 6 Cells | | | |
Contenu sponsorisé | Sujet: Re: [S][Demande de partage] Feuille de réglage Xerun 150A | |
